작성일23-09-18 00:36
조회5,426회
Kotlin 구구단
private lateinit var DanET: EditText
private lateinit var ExButton: Button
private lateinit var ResultTV: TextView
private var result:Int=0
private var danNum:Int=0
DanET= findViewById(R.id.Dan_ET)
ExButton = findViewById(R.id.EX_BT)
ResultTV = findViewById(R.id.result_TV)
DanET.setOnClickListener {
DanET.setText(null)
ExButton.setOnClickListener {
var danSTR: String = DanET.text.toString()
danNum = danSTR.toInt()
ResultTV.text=""
for (cnt in 1..9){
result=danNum*cnt
ResultTV.append("$danNum * $cnt = $result \n")
android:id="@+id/Dan_ET"
android:ems="10"
android:inputType="text"
android:background="#C1BDBD"
android:layout_gravity="center" />
android:id="@+id/EX_BT"
android:text="실 행"
android:id="@+id/result_TV"
android:layout_width="300dp"
android:background="#8CBDA5"
android:textSize="20sp"
android:textStyle="bold"
